5 spd conversion question
So I hammered out the transmission tunnel for the slave cylinder and put the 5 spd into place. I did not notice that it was still very close where the transmission housing that holds the slave cylinder is located. I would like to make a bit more room without pulling the trans again. Has anyone successfully put a pry bar into that area and widened it? It only needs like a quarter inch or so. Thanks in advance for any guidance.
i'd use a wooden wedge to gently adjust the sheetmetal. don't need to deform very much. too much and you'll have problems with the accelerator pedal clearance.
& 1 special alfa
