WTB driver's side rocker and/or the part(s) pictured
williamggruff
http://picasaweb.google.com/grice.mulligan/20090717OxidizedMetalAndYour2002ElectricBoogaloo#
Note the slight discoloration in the metal below the pretty horizontal trim in the photos linked above. Some might call this rust. I call it acne that resulted from teen angst. Regardless of the terminology applied, I'm eager to get rid of these unsightly blemishes.
Is this the rocker panel, or is this the metal beneath the rocker panel? Can this be easily replaced? If so, could someone please suggest a source and/or part number? The offending part is from a late 1974-76 (still unknown due to the number of PO modifications.)
williamggruff
williamggruff
That is your rocker panel--you can buy replacement pieces and do it right or cut that section only and replace with a good piece. Odds are that you will find more when you examine closely and you should do an assesment of your inner rocker as well as the front edge of your wheel tub/under your rear seat area----this is where your subframe bolts come thru. Those areas are prone to weakening due to the tin worm---scoyote
