E21 S14 Swap Need Wiring Help!!!
Hello everybody.
I'm about to begin my S14 conversion. All the parts are ready.
Next week I will be taking my M10 out and putting S14.
There is one thing I'm still not quite sure about, it's wiring.
I do not seem to find a good swap thread and do not have $300 for a swap manual from Aardvarc Racing. Please help me if you know anything about it.
Here is what I have:
1977 BMW 320i 2.0L M10
1988 M3 S14 with Fuse box, complete Engine and Part of interior harness'.
The harness is cut where it goes to Headlights and the part that was going into cluster. The other plugs from under the dash are uncut and have two boxes attached to it. One, I suppose, is ABS control unit. The other is a little black box I have no Idea what its for...
I will keep stock the ECU and other components on my S14.
Do I keep my fuse box or put M3 fuse box instead?
Any help is appreciated.
If you have any files, you can e-mail them to nikch86@gmail.com
Thank you.
Ok.
I found my C101 connector. I have both male and female part of the connector,
so I can wire my E21 harness to it.
Here is my question. What pins on the connector I have to use and how do I wire my
E21 harness to it. I do not seem to find a good E21 wiring diagram with the colors of the wires...
Also, I have 3 unused single wire plugs on my engine harness that I do not know where to connect. Maybe ground wires?
[/img]
  • 1 month later...
