Cigar lighter socket and GPS
Arshloch
I added another plug when I rewired the72. Had the same problem you are having. I'd suggest that you replace the original with a modern (uncorroded) version. If you pull yours and look at it you will more than likely see corroded eroded terminals which when the GPS or phone does draw power would not make them happy.
A simple no cost solution is to wrap narrow athletic tape around the plug your inserting in the cigarette lighter. I put one or two layers on the tip and another on the other side of the expanding clip that holds it tight in most standard size cigarette lighters.
I've found GPS systems are great for rallys indicating roads and road names up ahead long before you get a visual.
74 2002 w/sunroof & A/C - daily driver
71 2002 M20/260 - in paint shop
75 2002 parts car
74 VW Westfailia
69 VW Type 2 Weekender
2012 Jetta Sportswagon TDI
