Relay & Sensor Quiz
Every year at Mid America 02 Fest, Bo Black gives us a quiz, and the one who answers the most questions correctly gets recognition. Here's an easy one for some of you.
In my quest to order a part, I came across something I thought was interesting. The picture below has arrows pointing to certain items which can no longer be ordered; nor is there a description of the items.
Let's determine what these items are for future reference.
Thanks, and please help.
You'll have to enlarge the picture to read the red print which indicates the price and part number for those items still available to us.
'71 Agave, '71 Verona, '74 Inka, '73 Chamonix
"FAQ Member Number 60"
Mike,
With nothing else better to do, and armed with the parts manual.......
3 - 6v (& 12v) Flasher Relay - 1602 only
7 - 6v Headlight Relay - 1602 only
8 - 6v (& 12v) Washer Pump Relay - early '02s
11 - Relay for carburettor - US '02 & '02A only
13 - Mile counter for warning lamp & thermo reactor - US '02 & '02A only
14 - Mounting Plate for item 13
15 - Brake Pressure Switch - US '02 & '02A only
16 - Speed Warning Switch - Japan dely 1502 only
17 - Buzzer (for 16?) - Japan dely 1502 only
Ta da!
Les
'74 '02 - Jade Touring (RHD)
'76 '02 - Delk's "Da Beater"
FAQ Member #17
Mike,
Ta da!
Les, I was hoping that 15 was the temperature control for the cold start on the tii. Do you know that part number? Thanks
I believe #9 may be the tii cold start relay (1311354686, $265.68 at Real.Oem). When I priced one many years ago it was ~$100 and I just put in a push-button switch like was referred to recently.
#15 looks a more like a transmission reverse light switch than a brake light switch, but it is hard to tell. Real Oem shows the brake light switch as #9 on fiche 34/28.
Best, Fred
'74tii track
--Fred
'74tii (Colorado) track car
'73tii (Fjord....RIP)
I believe #9 may be the tii cold start relay (61311354686, $265.68 at Real.Oem). When I priced one many years ago it was ~$100 and I just put in a push-button switch like was referred to recently.
Best, Fred
'74tii track
Fred, I'm looking for the part number of the temperature control sender that tells the cold start relay when it's cold enough for fuel to the injector, or hot enough that it doesn't need it. It mounts close to the temperature gage sender and has two prongs surrounded by a bake-lite material to which the wires hook, surrounded by a rubber flat like sleeve.
Thanks
EDIT: I found it: A 13 62 1 355 006 delay switch
I should have one or two of those around somewhere. Let me know if you want a used one. After I did the push-button to replace the tii relay I replaced the tii sender with a second water temp sender for my aftermarket VDO gauge.
Fred
--Fred
Fred
Yes, a used one would work if the top is still intact.
Let me know how much?
Thanks
Thanks
Mike, I have two senders. Both are same length from crush washer down, one has a large head and good bakalite, the other has a smaller head and chipped bakalite. I tested both in a water bath, specs and markings on senders as follows, pic below.
Short Head Time Switch
VDO
35°C
150°C max
4.74
12V 40W
36/4/1
R_cold = 44.5 Ohm (T=20°C)
R_hot = 153 Ohm (T=52°C)
Long Head Time Switch
VDO Made in Germany
35°C
150°C max
6.79
12V 40W
36/5/25
R_cold = 51.9 Ohm (T=20°C)
R_hot = 220 Ohm (T=52°C)
I think a reasonable price is $18 + shipping. If interested, drop me a note at fbeck at sentech dot org
Thanks, Fred
--Fred
