74 TII in NC (carbed)
mysharona
$5000.00
I am the third owner, original owner stored car from 1984 until approx 1996 when owner 2 bought it, next recorded mileage is 5/98 showing 79,935 miles. I bought the car from #2’s small collection in 10/05 with approx 82,000 miles. The last accurate mileage recording was 12/6 showing 83155. The odometer failed shortly after. The point is that this is a true low mileage car, garage kept since 1984 if not longer. The car is wearing original paint and is in need of a fresh coat. This is a non-sunroof car, and has solid shock mounts, strut towers and very little rust ( spare tire well)
The car riders on Bilstein HD’s, upgraded sway bars, and cut sport springs. He has seen a couple of DE days in the last couple of years, and always came home in the same shape we arrived (with a few more smiles and stories). It has a fresh custom exhaust, and an NOS Ansa system is available, as are 13” baskatweaves, e21 Recaro’s, and an E21 3.91 LSD. The TII FI was removed and lost a long time ago, today he is fueled by a Weber 38/38 and runs GREAT, no stories no excuses, fast is relative but this car is fun to drive.
I’m selling because this car is not modern enough for full time family duty, and garage space is limited…and the e36 M needs to sleep inside.
Pictures Coming soon
Car is in Lewisville NC, 27023
Visitors Welcome
Mike
336-837-7795
msrpresnell@earthlink.net
Purchased 10/05 82k miles
10/05
New 3 point seat belts, 4 seats
11/05
MSD ignition, Petronix
1/06
Front calipers rebuilt, fuel tank removed and flushed
9/06
Rear wheel cylinders replaced with larger e21 style
11/06
New Carter Electric fuel pump/Holley fuel regulator
4/07
Replace front pads, flush with superblue
5/07
5-speed conversion, new oem clutch and slave
6/07
New rear brake pads installed
5/9/08
Motorsports connection, top end rebuild
New rocker arms, 5-angle valve job, flow head, flow intake for 38/38 Weber
100rwhp/106rwtq Dynojet
9/09
Steering system rebuild
Tie rods, center arm, rebuild steering box Korman, Rag joint replaced
change tranny oil Redline MTF, leaking rear output shaft not repaired
9/09
New battery installed
I might be interested. Any pictures are welcome.
Thanks
Dieter
deetman@sbcglobal.net
Current:
- 1970 Colorado 2002, 1982 323i, 1972 Porsche 914, 1956 Porsche 356A Coupe replica, 2003 Mini Cooper S
Past:
- 1980 320is Turbo, 1972 Malaga 2002tii, 1973 Polaris 2002tii, 1973 Sahara 2002, 1981 Alpina C1 2.3, 1989 M3, 1984 Hardy & Beck 327S
