Brake master cylinder shot?
E21kiwi
I have been fixing up the brakes. Having trouble bleeding. I can pump up a pedal to get the brakes to work but see very small bubbles in the reservoir. Is my master cylinder shot? And does it make a difference if you have the calipers swaped over either side ie nipple at the bottom pointing down.
1978 E21 2.7L
1974 2002
1967 1600
....and when judging the pedal travel,
you must always include adjustment of the rear shoes-to the drums for that j u s t skimming touching noise
while hand turning the rear wheels in forward direction - and backing off the adjuster a hair for no-noise while turning
the rims must be mounted tight
or suitable washers under the lug nuts with rims
so the drums are firmly seated on the hubs
Best with the rims mounted
if yer rear shoes are not correct (too loose)
your pedal will NEVER be correctly firm
'64 R27 250cc #383851 18,000m
I'll swap the calipers over and try a re-bleed. Didn't even think to check for left and right calipers-Doh! I'm new to the 2002 and E21's only ever had 2 pot calipers..but I have some volvo 4 pots going on and will be extra vigilant. Thanks for the help
1978 E21 2.7L
1974 2002
1967 1600
