Brake vacuum booster , master , slave cylinder rebuilder
c.d.iesel
http://www.whitepost.com/brakeform.html
Our rebuilt cylinders are better than new, they will never rust, pit or corrode, because we install brass sleeves.
We disassemble the cylinders, glassbead clean, bore oversize, press in the brass sleeve and size them to original specifications. We rebuild your cylinder with all necessary new parts and apply an original finish on the outside.
We rebuild vacuum boosters for all cars and trucks.
We also reline brake shoes and disc brake pads.
All work is guaranteed with a written Lifetime Warranty.
Quick Service - Same Day & Overnight. (Normally 2 to 3 Days.)
When you receive your rebuilt brake cylinders, they're ready to bolt on your car, and you'll never have to touch them again!
for those of you discussing brake booster failures
and wanting another rebuilding reference
I have no connection other than meeting
the owner Billy Thompson at Carlisle,
and all the great press about their services
'64 R27 250cc #383851 18,000m
A co-worker sent a set of Corvette brake calipers to them for rebuilding years ago. They came back in like-new condition with sleeved piston bores but it wasn't cheap!!
I've always wanted to visit their facility.
I had White Post rebuild the master cylinder and calipers for my 2000CS years ago as they were already NLA then. Cost about $500 then. I did have a seal leak and they repaired that under their life-time warranty.
White Post has been around for many years and has done a lot of high-dollar restorations. Our local BMWCCA chapter used to go there on tours in the past and visiting was always interesting.
BMWCCA #2762
72 2002/71 2002ti, 67 2000CS, 2x 72 3.0CS
86 635, 2x 05 330Ci ZHP,
'11 Corvette Grand Sport
It's been close to 10 years since we took a tour. They were restoring an Anthrazit '74 tii with ~9K on it. Owner is David Landis (?) in the Potomac MD area.
Mr's B's bbq is just up the street from the facility.
Make the call, Jim!
John in VA
