M10 powered Lotus Seven clone
dadandson02
I am contemplating building a Lotus Seven clone using an M10 engine. Want to keep it simple and cheap. What bugs me is the distributor that protudes above the top of the engine. The carb, or a tii plenum, would also protude above the top of the engine. Dont want to raise the hood just to clear these and dont want bulges all over. Would be willing to go with Lynx & 45DCOE sidedraft but still stuck with the distributor. Go with a crank triggered ignition ? Seems like Megasquirt II would be the cheapest setup. But then again, all this fuel injection hardware just to get the capability to control the advance curve from the EDIS4 ! Any thoughts ?
Do some googling on Megajolt - it's a "MS-similar" standalone ignition controller, cheaper and simplier to install.
Regards, Mike
Unless you're completely committed to the M10, consider the Toyota 4AGE twin-cam -- it's a Cosworth BDA clone according to this source:
http://www.billzilla.org/4agstock.htm
It's a great motor (1600cc), cheap to source, quite compact, and has the potential for performance well over 200hp.
Delia
And...it fits under the hood...no "panty lines"...!!!
1973 2002tii - gone
Inka (aka "Orange Julius")
#2762756
1974 2002tii - gone
Polaris (aka "Mae West")
#2782824
1991 318is (aka) "O'Hara")
deliawolfe@gmail.com
Here is a turbocharged, intercooled M-10 in a Caterham from SoCal vintage 09. Photo courtesy of JKBIMMA
Seems to have reg distributor, but modified hood.
This is what I plan to do with my NK 2000. - use a Megasquirt II , just to run EDIS. But then, I plan on perhaps going FI in the future, if my Solex's don't treat me right.
I looked into Megajolt, but found that the assembled cost is $125, (the kit version is Surface mount componentry, so I dont want to mess with it).
The MS-II kit version (not surface mount, so I can build) is only $250 on ebay. so I am just going to go for the MS-ii for ignition control, and have the FI capability waiting in the wings.
73 Riviera Daily driver 2002 - MS, 9.5:1, cam, LSD
One of my friend has a catheram super 7 and isntalled a 1.8 tubo engine from a nissan silvia iirc (CA18DET), and i installed for him a SDS EM4F, distributor less.
easy fit, the guy lives close to Sherbrooke (QC).
The car is unbeatable on mecaglisse iirc.
1985 XR4TI, 22psi ±300hp
Unless you're committed to the M10 as a novelty, there are much better powerplants out there for a Caterham or Birkin.
Why go with an antiquated motor and ignition? Get a Ford Zetec or crossflow, lighter, more tunable.
My buddy has a birkin super seven w/ Zetec ands it flies. Great ignition and EFI and any ford dealer can supply service or parts.
Cheers!
1976 BMW 2002
1990 Porsche 964 C4 Cabriolet
I worked on a Rotus & with an M10 in it. The distributor was in a "lay down" housing similar to the ones I have seen in Elva Mk7-Mk8 and Chevron B8 and B16 racecars.
I this folder I have pictures of a couple of Elva's w/ M10's with lay down distributor housings...
http://s121.photobucket.com/albums/o236/tjones02_bucket/Wine%20Country%20Classic%2007/
Information on Chevron cars here...
http://www.chevronracing.com/
L.H Owen in the UK should be able to provide a "lay down" distributor housing for you.
http://www.bmw2002faq.com/component/option,com_forum/Itemid,0/page,viewtopic/t,315181
Elva, Ginetta, Lotus 23B, Chevron B8 B16... These Threads have more pictures...
http://www.bmw2002faq.com/component/option,com_forum/Itemid,57/page,viewtopic/t,307952
http://www.bmw2002faq.com/component/option,com_forum/Itemid,57/page,viewtopic/t,110558
http://www.bmw2002faq.com/component/option,com_forum/Itemid,57/page,viewtopic/t,290487
http://www.bmw2002faq.com/component/option,com_forum/Itemid,57/page,viewtopic/t,308929
This Elva has a Mallory Distributor, the lower portion fits an 02.
Sorry for the red color, I did not have a filter to take their tent color out. Another Elva Mk8.
Too bad Rotus is out of business, they had the plans for the M10 install car that I drove.
Tom Jones
In one of the previous threaded links someone mentions that Ireland Engineering built a motor with one of these lay down distributor housings. They might remember where they got it from and help you get another.
http://www.iemotorsport.com/
Tom Jones
  • 2 years later...
HI,
I have a Locost rolling frame with a M10 engine for sale. Project is well advanced. Lost of part. And I'm in Quebec.
Nicolas Leroux
nleroux@gmail.com
