Anyone in the Bay Area have a clutch alignment tool I can bo
pyite20v
borrow? Took my trans out to inspect the clutch, and happy to find it looks pretty new. Just need it for a day or two, the engine and trans are out of the car.
76 Jade Green w/ E21 2.0 - DCOE Weber 40s, 304, 5spd, Stahl>Ansa, Wilwoods, H+R and Bilsteins, and some other fun bits.
CLutch alignment tool is not all that critical for reassembly. If you are in the business, where time is a premium, the cheap plastic or wooden tool is a must have. I keep a trans input shaft for that purpose, but have rarely used it. I have a large flat head Stanley screwdriver. The handle lines everything up just as well as the input shaft. I used it last weekend with an E21 and it was borrowed for a 65 Ford 3 speed the week prior. But even without a tool designed specifically for that purpose - if you have enough access and light, you can visually line things up and if necessary tweak things with an imaginative use of an appropriate sized dowel or lengthy half inch drive extension.
hth
