starter noise....
dp2002
Tried to search first, but no luck, so help is needed.
I want to know if I need a shim for this starter
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=380188260628&viewitem=&sspagename=STRK%3AMEWNX%3AIT
It is making some noise when I start, but it works. Makes a grinding noise like gear grinding.
TIA
1971 BMW 2002-Chamonix
http://whitey02.blogspot.com
I have one of those sitting on my shelf for the exact same reason. Check the length of the bendix, or the length of the housing around it. I bet you find it's shorter than the stock starter. Upon initial install of mine, I turned mine over a few times, and heard a nasty sound. So I took it back off & found it trashed 3 teeth on my flywheel. The bendix on mine doesn't go over the flywheel far enough.
The seller I bought mine from "starters-alternators" on ebay, would not return my calls, or emails. It was some women working out of her house. (and English was not her 1st language.) I see she's still at it.
Esty. Does your work fine?
mine work perfectly
it's disappointing to see the problems with the starters...i've never had any problems...i also bought a hi-output starter for a 57 ranchero and it's been going strong without any problems
i'm not absolutely sure after taking a 2nd look that this is the same ebay vendor that i bought from...i couldn't find the old auctions, it's been a few years ago...but i think it's the same vendor
