tii dizzy and header upgrade, why?
dma
I installed the Tii exhaust manifold to eliminate my Thermal Reactor oem unit. It appears to have slightly better flow and weighs a lot less. Car runs better, but that may be misleading because I had a number of leaks due to partial and jerry-rigged desmogging.
The Tii dizzy lacks a vacuum advance and you can 'tune' it, or more precisely, 're-curve' it using different springs/weights to move the advance around the rpm range to optimize your individual setup.
Cheers!
1976 BMW 2002
1990 BMW 325is (newest addition)
1990 Porsche 964 C4 Cabriolet
+7 HP if you use a dwell meter,
timing light, and exhaust A/F ratio tester.
+23 HP if the motor was in krap condition
and now it gets correct attention (that's +23
to the lousy runing 70 - really)
'64 R27 250cc #383851 18,000m
now hold on there just a 'cotton-picking' minute....
i had nothing to do with desmogging your car and the 'alleged' airleaks.
sheeeesh....................
& 1 special alfa
I actually think the tii dizzy's not right for a carbed car. It doesn't have enough
total advance, and won't give you enough advance at light- throttle
cruising.
In EFI terms, it's missing an input- it doesn't know where the throttle
is.
Having said that, CCD is right- any dizzy in great shape is better than any
other worn- out dizzy.
fwiw,
