For Trade: 1991 325i with m30b35 *Pics&Videos* --- PA
yert315
I bought this e30 about a year and a half ago with plans to use it as a daily driver. I am the second owner. The previous owner was a gentleman in the army who bought it from the dealer in 1991. Soon after purchasing the car, the head gasket blew. After my first attempt to fix the problem failed, I decided to swap in a m30. Here are the details on the car:
The body:
- An original Texas car (just moved from San Antonio a couple weeks ago)
- has about 150k miles on it (odometer stopped at 143xxx)
- has a dent on the passenger side fender
- roof paint is faded (a detail may be able to clear it up)
- slight surface rust on front driver's fender where it meets the bumper
- new brake pads (Thanks Jakeb!). Pad wear sensor needed
- new battery - 3 year warranty from Walmart
Interior:
- Factory "comfort" seats - rips in driver's seat others are Clean
- 99% crack free dash - crack in the passenger side indent
- custom shift and e-brake boots - doesn't have the frame to clip in
- premium speakers - factory
- Old aftermarket Alpine head unit
- fuel gauge does not work (however, the low level gas light IS operational)
Drivetrain:
- m30b35 out of a 1989 735i - every, and I mean every, gasket and seal has been replaced (head gasket, oil pan gasket, intake manifold gaskets, exhaust manifold gaskets, timing cover gaskets - upper and lower, valve cover gasket, throttle body gasket, water pump gasket, thermostat housing gaskets, rear main seal, front cam seal, front crank seal)
- new timing chain, tensioners and guide rails. incl. oil pump chain tensioner
- new water pump
- rebuilt oil pump - oil pump nut loc-tited on
- new ignition cap, rotor and wires
- new 19lb fuel injectors - Bosch design 3
- New 140A alternator
- 5-speed transmission out of a 1987 535i - shifts fine in every gear
- Polyurethane engine and transmission mounts
- stage 2 racing clutch. new when the swap was done
- new center support bearing
- new clutch master and slave cylinders
- 2.93LSD differential with fresh 90w gear oil
- e24 exhaust manifolds and down pipes mated to factory e30 exhaust
- 2600CFM electric pusher fan controlled by a switch mounted next to the rear defrost switch
- *heater core is not hooked up*
Suspension:
-Everything is completely stock as far as suspension goes.
I finished the swap, after a year of working on it, a few months ago and worked out all the kinks. For what it's worth, I plan to make a 3 hour trip to MD next weekend.
Here are a ton of Pictures:
http://s115.photobucket.com/albums/n290/yert315/E30%20for%20Sale/?albumview=slideshow
Couple Videos:
http://www.youtube.com/watch?v=SoDk4m5x5-Q
http://www.youtube.com/watch?v=GZAPvkQRDtg
What I am looking for:
I would like a pre '73 model in good running condition with minimal rust (I know, the east coast). Preferably any color but red, but will consider it. If I were to sell the car I would ask for $4500, so trades equal to or less than that would be ideal.
E-mail, PM or call with questions/offers 210-347-4378. Car is located in Allentown, PA.
Thanks,
Trey
  • 3 weeks later...
