1968 2002 / M20 Project for sale, for sale, MUST GO!
scottiesharpe
For sale: this was a running driving car that I pulled the driveline out of last fall in hopes to do an M20 conversion. A new job and a new found love of motorcycling (BMWs of course) have me pointed in a new direction.
Lots of new parts from Ireland engineering. Tons of neat modifications. Lots of nice stuff like brand new black cordoroy Recaro seats (tags are still on them) in new condition (of course), new Ireland coil over suspension with shortened tii struts and e12 / turbo brakes (already installed and dialed in!). 4 point half cage. 4-point seat belt. Lots of vintage stuff like euro turn signals, working cluster clock, dash top VDO tachometer, SW guages, Nardi wood wheel and wood shift knob, and more!
The M20 engine was removed (by me) from a 1987 325i automatic owned by a normal family in Manteca that was rear ended. The car had been serviced normally and I think I still have the service records for that car. It had a timing belt service done just prior to being totalled. I bought it because it was in an automatic car and it is my theory that autos make good donor engine cars because they spend most of their lives below 3,000rpm.
Also included are several drive drafts (to make a custom one), and a 5-speed transmission from M42-powered 1991 318i (works and shifts great - I drove home and parted the 318i to get the tranny) come with car.
Like I said, this was a running driving car. The front and rear suspension was professionally four-wheel aligned for toe-in front and rear, camber front and rear to Jeff Ireland's suggested track settings (in the FAQ) by Professional Alignment in Mountainview ($375).
Here is a list of modifications and approximately how much I have invested in each item.
"14x6.5" BMW 325is basketweave wheels (6 included wheels) $400
Front Suspension
TII Struts (shortened to Ireland specs) $300
VW Rabbit Bilstein Sport front strut inserts $240
Ireland Coil Over front strut kit $300
Ireland Front adj spherical bearing camber plates $200
"Ireland 400 lb 3x7"" front springs" $110
Ireland 20mm hollow front sway bar $150
Custom Aluminum Strut Bar by Ethan Turner $100
Rear Suspension
Limited Slip 3.9:1 from 320iS $250
"TII rear swing arms, sand blasted, painted, bearings cleaned and serviced" $450
Ireland poly swing arm bushings $60
Late model subframe $100
Ireland 350 lb rear springs $100
Bilstein Sport rear shocks $150
Ireland adjustable subframe kit $350
Ireland 20mm adjustable rear sway bar $150
Half shafts modified with 320 inboard CV joints $100
Trunk mounted battery in Stiffy Werks rear brace $150
Engine
M20 Engine $650
5 speed transmission $400
Ireland poly transmission mount $60
Exhaust
"Straight pipe, no resonator, 02 bung" $100
BMW 2002tii factory rear exhaust $100
Quick disconnect near subframe with extra hanger for open pipe track use 100
Chrome tip 35
Electric fuel pump with metal line $100
HD cable actuated throttle linkage $50
e21 Electric Fan $100
Brakes
"""Earls"" stainless steel braided soft brake lines " 110
Front
1977 320i front hubs $75
e12 4-pot front calipers $100
320i Vented Rotors $75
2002 Turbo Front Backing Plates $50
Rear
320i rear brakes no parking brake $200
6 point roll bar not installed $100
Interior
Heater box delete
Hiflow quiet fan aux heater from RV Supply company $100
oil press and battery amperage $75
Recaro Seats $1000
Custom short shift kit $150
Momo carbon fiber shift knob $50
4 point belt $80
Nardi wood steering wheel with BMW horn button (not connected) $250
Stuff included, but not done yet.
Install M20 driveline, tranny - assorted engine mounts included for modification
Custom driveshaft
Install high pressure fuel pump, included
Install Return fuel line
upgrade/stregnthen front control arms - extra set of arms included with car
Ireland Eng front control arm poly bushings (kit $60)
Body is "fair" - meaning it is solid but it has rust here and there and surface rust. Was never intended to be a show car. Floor boards will need to be repaired. All structuural items appear to be solid. I've driven this car in the hills and on the auto-x course and it has worked great. Super handling and fantastic brakes. Will need new tires, but has worn tires on it.
Car is located in San Jose CA, is registered non-op, is smog exempt and is towable.
Make offer via private message or email me at scottiesharpe on gmail dot com.
I'm asking $4500. As you can see, I have twice that invested.
If you have been thinking about a 2002 project and want an EARLY round tail light NO TRIM, NO PARKING LAMPS, NON TINTED GLASS chassis to work with, this project is for you!
Lots of pics are located at http://picasaweb.google.com/scottiesharpe
Come by anytime and look it over and we can discuss.
I am not looking to part this out. However I will consider selling the car without the M20 & tranny.
Best, Scottie
Scottie Sharpe
68 2002 Mikunis Ireland coilover e12/e21 brakes
88 Dinan M5 stage 4 M88/3 conv, Miller MAF, B&B, 3-pc Fikses 17x9fr, 17x10rr, Racelogic traction and launch
Webmaster for http://bmwturboperformance.com
Do you www.bmwWikiWiki.com ??
BUMP. As I mentioned this must go. I need my garage back.
Price reduced to $4000.
Scottie Sharpe
