FS 1970 2002 Rebuilt Engine. Lots of new parts. Location CA
Carbon
1970 BMW 2002
I bought the car this last fall to replace my 1991 318is that was totaled. The car was owned by an enthusiast who owned 2 more 2002’s and a bunch of other classics. He had just rebuilt the engine and installed it in the car before it was sold to me. The wiring was not finished and a lot of other things needed to be addressed before it was drivable. I went through and started fixing/replacing/rebuilding everything I could. Most of the car mechanically is pretty much brand new (installed within the last 4 months). The car has about 4,000 miles on everything now. It has been my daily driver since the fall but now I’m looking to get back in an e30. I tried to be a thorough as possible in this ad. Pictures will be coming soon. Just need to find a sunny day to wash her and snap a few.
Suspension:
-Dinan Springs
-KYB Shocks
-Upgraded sway bar for front (Not Installed yet)
-Trunk mount battery tray/strut brace (Not installed yet)
Brakes:
-Brand new brake master cylinder
-Stock rotors and calipers and pads in good shape
-Freshly bled with ATE Super Blue Fluid
-New blue soft lines from reservoir to master
Exterior:
-Almost complete aluminum trim in good shape (Missing trunk middle belt line and drivers door belt line) Rockers and two of the trunk pieces not installed yet.
-Kamei trunk lid “Turbo” style wing
-Front and rear chrome bumpers (front not installed)
-Decent paint (There are some flaws but she is good at 10 feet)
-New front and rear windshield seals and new lockstrips
-New door seals
-3 original BMW hubcaps
-Flush front euro turn signals
Interior:
-Almost perfect dash with one small crack (Not installed yet)
-Momo Course Steering wheel
-Great condition 320i Recaros front seats
-Good condition back seat (some fading but no stains or rips)
-New headliner
-Leather BMW shift knob
-3 gauge pod with VDO amps, water temp and oil pressure. (Not connected yet)
Engine:
-Rebuilt m10
-Decked block
-Turned and balanced crank
-9.5 to 1 pistons
-292 custom camshaft
-Rebuilt head (All wear parts replaced)
-New rockers
-New valve springs
-New valves
-Equal length headers wrapped in fiberglass heat wrap
-Brand new Ireland engineering 2” stainless steel exhaust
-Weber 38/38 carburetor
-Hogged out and port matched “peanut” manifold
-Polished valve cover and other aluminum engine pieces
-New seals/gaskets/etc
-New 320i Radiator
-New coolant lines
-New vacuum lines
-Battery relocated to trunk using e30 battery cable
-New 65 amp 320i alternator
-New gas filler neck
-New Bosch ignition coil
-New Bosch plug wires
Transmission:
-Stock 4-speed
-New Guibo
-New clutch master cylinder
-rebuilt shift linkage
-Fresh Redline Transmission fluid
-Re-built pedal box (used Blunts kit)
Other:
-2 5-speed 320i overdrive transmissions (I was told one was rebuilt and for some reason reverse did not work anymore after the rebuild and the other is supposed to be used but in good shape.)
-Lots of other interior bits and pieces (Door Cards, stock seats, perfect black bottom half of rear seat, interior panels, center console)
-Stock carb, manifold
-Assorted seat belts
-Lots of other stuff in boxes
Issues I haven’t addressed yet:
-Some rust repair (Drivers side floor panel, passenger side front and back floorboard. Not horrible but needs to be fixed.)
-Side window seals (Current ones are old and cracking)
-Trunk lock does not have a key
-Front drivers side wing needs the dent pulled, body filler and paint
-Some other body work. The paint isn’t great up close but it would look great with a little body work and fresh paint. Dents in the hood. Some light surface rust here and there.
-Gauges need to be grounded (They hop around from time to time)
-Needs sound deadening and carpet
-The good dash needs to be installed
-Battery tray/rear strut brace needs to be mounted and battery cable screwed down
-A little rust in the spare tire well could use some attention
-Transmission grinds if you go too fast into second
-Diff fluid needs to be changed
-The trunk seal is decent but in really heavy rain it leaks a little
-A few very small cracks in the back left brake light
-Some rust on the top of the back bumper (Could use a fresh chrome dip)
-No choke installed on carburetor. Starts and runs fine but does take a little while to warm up
-Heater does not work
Overall I have put $3000 into her since purchased. Not including labor or the the full engine rebuild the previous owner did either. This is a great car and won’t require too much more work to be a great daily driver or weekend car.
I’m asking $5000 for her and the parts and two 5-speeds.
I will consider trades of equal or lesser value plus cash on your part. I want to get another e30, so anything 1988 and up would be nice, or older e30’s with euro bumpers. I do prefer 2 doors but am not completely against a 4 door. I want something with low miles in good mechanical shape. This has to be my daily driver.
I may consider other cars as trade too.
Thanks for looking! Let me know if you have any questions or would like to come see the car. I'm located in the North Bay, Rohnert Park, CA.
-Richard
Here are some dirty pics of her. Still waiting on a dry day off work to wash her and get some better pictures.
