Master Cylinder Cross Section
doug73cs
here ya go..
Ususally you do not need to bench bleed these 02 MC, but when needed, take several short lengths of hard line and screw the fittings into all the outlets, then route those pipes (with hose extensions if required) to dump fluid back into the reservoir & bleed all the air out of thje MC (you could do this on the car.)
Then, reassemble the brake plumbing and bleed all the corners again
John:
Thanks for the drawing. I've done all of the pre-installation bleed, installed the MC and bled to system as per the faq guide. 100% air free in the hardlines and MC - until I push the brake pedal.
Doug
If we learn from our mistakes does that mean I have to make them all?
73 CS Polaris
76 2002a Sahara
