WTB output flange for getrag 245.0.540
pikeperkins
IMHO there is not much difference. A couple things you should keep in mind are, if you use the three bolt flange use the Jurid flex couple because the others will come too close or even touch the shift mechanism, also if you do use the bolt output flange the flex couple is about 3/8 inch thinner so you need to take that into consideration when shortening the driveshaft.
Ceylon 1973 2002tii 2762669
1972 Austin Mini 1275 traded
1970 Barracuda Convertible
1974 Schwarz 2002
1955 Chevy Bel Air 2 Dr Hardtop
