somethign i am working on. EFI
steve k.
  • Administrators
Have you considered going to manual brakes? SP allows any single master cylinder and booster (or no booster).
I am evaluating my brake options right now. It will take some calculations to figure out proper MC. But i will do that after i get lighter disks all around.
steve k.
Get your 2002 FAQ merchandise from 2002FAQ Store
  • Replies 32
  • Created
  • Last Reply
Top Posters In This Topic
Very nice, Steve. Do they make a banged up, covered in patina and oxidization version that would pass for vintage racing? ;)
Shad
'70 2002 #671 "Bimmerschmitt"
'70 2002 BADUDA aka 'Wall Art'
'72 2002 #672 Sold
'73 2002 Sold
'79 528i Daily Driver (future ETC Clone)
  • 3 weeks later...
  • Administrators
Updates to the EFI progress, in pictures.
Test fit:
Hose and fittings arrived from http://www.lpiracing.com (Thanks Mark!)
Fuel Filter
Fuel Pump from http://www.2002haus.com (Thanks Rob!)
Plumbing and wiring in the trunk:
Tapping the hole fro 3/8 NPT Water Temp Sender
New header from http://www.bmw2002.com
Old header cracked the the front. Too many speed bumps
Under car Plumming
Rivets go in
New Alternator, 6lb, 50 AMP
i'll be posting all photos to
steve k.
  • Administrators
A few more things done this weekend. Redoing a lot of wiring and finding places for new component.
Mounting fuel pressure regulator to vacuum rail
Found a place for coils
This is where the battery lead terminates under the hood. Adds a place to jump the car and an easy positive.
This is where the rest of the positive leads will com from
steve k.
  • Administrators
Installation continues.
The ITBs are now mounted and bolted in. You can see the place for the throttle cable in this photo.
The final hose is in place. You can also see the new coolant temp censor for the ECU. I also have a fan coolant temp gauge censor and and fan switch. The switch will not be used any more since TECgt has a programmable output for that.
The hose from the rail to the Pressure Regulator going around the linkage and the coolant censors.
The plumbing is completed and tested. Got the pressure to about 60psi and there were no leaks. Had to add a little piece of BMW hose on the fuel pump side and 5/16 to AN6 converter since the Aeroquip hose was too big for the pump.
Found a plug in the firewall. This was probably for the AC. Can anyone confirm? It's on the passenger side under the glove box. Pulled it out. This will be the place for the harness.
The ECU itself will be sitting in the the console. I think the fuse box and a pair of relays will be mounted on the firewall in the glove box.
I sorted through the harness and labeled all the wires. Also separated them into bundles of weather they are staying in the cab or going into the engine compartment.
steve k.
  • Administrators
A few more photos. made a copper heat shield for the O2 sensor. Not sure if it will actually fit. Might be a bit too big.
Tom from 02 Again made a couple cool things for me. Attached the trigger wheel to a small aluminum pulley, and made a magnetic trigger holder. All aligned. Pretty cool stuff.
steve k.
Steve - the hole in the firewall seems to be on most 2002's. Not sure what the original intent was for. Here is my car with the (2) upper holes for the A/C lines and the extra unused hole I used to route my 02 sensor cable.
  • 1 month later...
  • Administrators
The EFI project is over. First race is tomorrow. We'll see how that goes.
Here are the final photos. Those who went to BayArea02 show already have seen the final installation. Now the car has been tuned and seems to run well.
steve k.
