Since we (mostly) all live with rust on our 02s, here's an
Mike Self
interesting comparison of various penetrating oils:
Machinist's Workshop magazine actually tested penetrants for break
out torque on rusted nuts. Significant results! They arranged a subjective
test of all the popular penetrants with the control being the torque
required to remove the nut from a "scientifically rusted" environment.
Penetrating oil Average load
None ..................... 516 pounds
WD-40 .................. 238 pounds
PB Blaster ..............214 pounds
Liquid Wrench ...... 127 pounds
Kano Kroil ............ 106 pounds
ATF-Acetone mix... 53 pounds
The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic
transmission fluid and acetone.
Note: The "home brew" was better than any commercial product in this
one particular test. A local machinist group mixed up a batch and all now
use it with equally good results. Note also that "Liquid Wrench" is about as
good as "Kroil" for about 20% of the price.
Anyone every mix up any ATF/acetone?
cheers
I've mixed up a 50-50 mix of acetone and ATF, and it seems like the acetone might have evaporated pretty quickly, leaving mostly ATF to try to penetrate. I've noticed other penetrants seem to be more like a thinner oil than ATF.
I need to get a good test subject to try again, but I wasn't very impressed the first time.
vince
I have a quick word of warning about the ATF-Acetone mixture.
Hexane/Acetone mixtures were pretty common as degreasers in recent history, but were phased out because of neurological problems caused by the metabolism of hexane. Hexane can't get into your body efficiently, but when it's dissolved in acetone, it passes through your skin much more easily. Therefore, you could potentially be increasing your risk to whatever is in ATF. Please use some protection when working with this stuff!
http://www.cdc.gov/mmwr/preview/mmwrhtml/mm5045a3.htm
(I just finished getting my PhD in chemistry and helped out with the green chemistry classes. A lot of toxicology info was given to us and I'm glad I can pass it along to people outside of the chemical world!)
an old seasoned 'gearhead', who's been around muscle cars since the 60's told me they used to use plain 'ol coca-cola squirted onto rusty nuts and bolts to free them up. he'd pour it into a squeeze bottle for dispensing.
i'm guessing the phosphoric acid in coke has something to do with attacking the rust.
& 1 special alfa
Another product is the CRC Freeze Off "sauce" - the stuff actually seems to work - used it on a few thoroughly corroded nuts & bolts without having to break out the Air tools.
http://www.crcindustries.com/auto/content/fzo.aspx
FWIW - The toxicity of the acetone in the ATF/Acetone mix kind of scares me. Having worked around "bio-hazard" chemicals like Acetone, MEK, Trichlor, etc., I learned to be very careful about being exposed to these chemicals in an uncontrolled environment (i.e. in my garage).
Andy W.
'72 Tii & '74 Tii
'88 M3 & '91 318is
