Parts! San Jose, Ca.
AClockworkOrange
JUST ADDED:
Accelerator Linkage from 71 with 32/36 Weber when removed 35?
ADDED:
Plastic surround piece for automatic shifter base 10
trunk lock and latch-no key 20
Wing window regulator, Inside Door handle Regulators, May have Window regulators as well 10 each
Trunk plug for sunroof car at least one maybe both 5
_____________________________________________________________
Bumper Ends for Front!
CORRECTION: Passenger sides not drivers... Too many parts!
Early No rubber passenger side-very good condition 55
73 passenger side with rubber-very good condition 55
Bumperette-Torn rubber mount-very good condition 25
I think these are about the best you will find unless rechromed or new.
Not sure why these aren't selling? Too much? No one wants just the ends?
I also have the rest of the 73 bumper with brackets and other bumperette but there are some bends. Looks like it could be straightened fairly easily (I may do it myself and update). 65 for the rest of the bumper with brackets. If Interested-will send detailed pics.
Manual-Haynes-Red 15?
Grills Nice 74-76 pair 35
Fan 20
Arm rests-Pair-Saddle 40
Wiper linkage - one with motor 65- one without 25
Center grill one early straightened-pitting-faded paint-tool marks-still good driver 35
Heater cores 2 good condition 25 each
Heater fan good condition-Fan loose from storage-not bent-30
Switches - knobs good to excellent condition 10 to 25
Blinker-Wiper Stalks 20 to 40
Intermittent wiper stalk 50
Rear side panels-Saddle 15 each
Rear Ashtrays-Saddle 5 each
Water outlet with 2 temp sensor inputs- Nice if you want to run an after market temp sensor and keep your stock gauge working-Electric fan switch-turbo stuff ect.-rare as far as I know-1 wire and 2 wire sensors included 45
Bosch Blue Ignition coils 15
Right side flag mirror nice shine-couple of small dings-no mount! 35
Vitaloni Plastic sport mirrors pair 20
73 Over Steering column pad/panel with vin # 10
Pretty nice round VDO Wiper fluid container with pump-Not much yellowing-had some overspray-Most of it has been cleaned off-you finish it 35
Under dash carboard some nice some not 5 to 10
Sun visors pair used-no cracks-very little sagging-Nice drivers 35
2002 emblem 5
Sun roof handle used but nice 15
Headlight buckets no rust all parts springs good function perfect 20
Shock mount riser rings two sizes for taking back to US stock look or?
pair 5
Sunroof dome light with trim ring-Very nice 20
12 fuse box 30
Distributors-parts various states of condition 008's & others 5 to 100 for all.
Dist caps with good wires 15
325is Basket weave center caps 4 very nice 85
Perfect passenger side wing window assembly with good glass/rubber/chrome-Mine was damaged from break in-never replaced it. 40
SS trim pieces Some straight-some not but repairable. 5-10
Bottom of Door Entry Plastic trim with rubber-pair 40
OEM air cleaner housing-offer
Winter preheater box-This may be from a 320i not sure-spring good-lever locks like it should for summer 25
Good condition rear roundie light housings x4-USA version 25 each
73 Plastic shift console-shift pattern on it + boot 25
320IS Steering wheels-One nice with collar/basket cover-nice leather 120- One without collar-Leather shot at top of wheel-Still looks good with cover and adds safety of crush basket-35 Horn buttons included
Pretty clean driver door body-unloaded-Ready to ship to East Coast!
One tiny almost undetectable rust spot. Bought to restore my door, never got around to it.
Very straight aside from two small dings from storage -Easy repair-45
Exhaust heat shield 15
Exhaust manifold earlier with one small air pipe. 100
Century polished aluminum turbo intake with throttle body
(made for injector in head motor or modify?) offer.
1.8 Intake Manifold with injectors and fuel rail + cold
start/boost injector (good for any m10 turbo/fuel injection project) 75 or offer.
CORRECTION 1983 E12-NOT E21 HEAD
M10 E21 Non Injection Big Valve Head-With smoothed valve cover-Looks good-valves look good-The car it was on sat for an extended period-Will probably need to be freshened up/overhauled 150
E30 2.5 '91 m20 head 130k Taken from bad automatic transmission 325i-looks good-Valves look good 150
Set of retractable seat belts from 73-have to check to see if I have female ends just yet 50
Sunroof wind deflector-smoke color-no clips-not sure where rubber strip is 10
Old school big round horn button 5
battery tray-solid 10
Trunk vent tubes black and grey sets 10 each set
H4 Autopal Flat Face Headlights with cheesy blue bulbs-No pitting on glass-Like new 35
Good radiator-35
Probably have a few more things to dig out-Will update if I find anything else good!
I will be putting some grab bags of stuff together soon to liquidate the small stuff.
Feel free to make me an offer if you don't feel my prices are fair!
I need to clean out the garage!
Add $5 on up for shipping depending on size/weight and 3% for PayPal...
Please email "Turkishgold88 at hotmail dot com"
Thank you.
Interested in the driver's door. Can you email me pics to 2double02@gmail.com?
1960 Austin Healey Sprite | 1974 Ford Bronco | 1974 Porsche 911 | 1989 Mustang GT | 1995 Porsche 911 | 2017 Porsche 911 | Always in Search of a BMW 2002
