1985 Euro 320 w/ M50 - SOLD
M3M3
2002 related because this must go to provide space and resources for the M2 project...
FOR SALE
1985 European 320 sedan with NV M50 conversion, Karminrot with gray M3 interior
This is true European model, not a re-bumpered US model.
Lightweight – no power windows or sunroof
1985 means it is over 25 years old so it qualifies for antique plates and no emissions inspections on some states (like Virginia)
The good….
ENGINE
92 NV M50 from a convertible
Compression 205psi on all 6 cyls +/- 8 psi
Adjustable Fuel Pressure Regulator with gauge
New radiator and starter
Entire intake track from air filter to manifold and injectors just removed and cleaned
Fresh oil and filter change
Both of the dreaded oil filter housing o-rings just replaced
No cat converters, resonators instead
Ansa muffler
TRANSMISSION
97 Z3 5-spd with fresh Redline MTL
DIFFERENTIAL
2.93 high lock LSD with fresh Redline 75w90
BRAKES
325 disks all around (Euro 320’s came with rear drums stock)
Fresh brake fluid
SUSPENSION
E30 M3 alum control arms
Billy sport shocks
H&R springs
Eibach polished front strut bar
Aftermarket thick sway bars with urethane bushings and adjustable end links
EXTERIOR
Repaint in original Karminrot euro only color
No dents or door dings
M-Tech 1 front airdam and rear valance
BMPD side skirts
Tow ring extenders front and rear
INTERIOR
White gauge face with blue or green backlight
M3 front and rear seats. All functions work
Cerwin-Vega speakers front and rear
The BAD
Drivers seat need recovering
Needs radio antenna
typical dash crack at top of cluster
i am picky, but the shifter bushings could use refresh
Needs new tires
A/C does not blow cold. no idea why..I don't do A/C
speedo works, odo does not
I just finished a major maintenance on this car in anticipation of using it for my commuter car. Went through all the mechanical and electrical systems, checking or replacing if needed. But, a new project just appeared in my driveway and this must go to make room.
$5k.
lytlehome at cox dot net.
More pics at
http://s397.photobucket.com/albums/pp59/mblytle/Euro%20320%20for%20sale/
2xM3
