WTB BMW 2002 Steering Wheel- PURCHASED
kwehmann
My 2002 came with a 320i steering wheel, so i'm trying to put everything back to normal. thanks!
Hi
What year is your 2002 just to see what wheel-model year option?
jb
'69 2002 (M2 for 2012) daily driver
'71 911 T (2.4s) powered Weekend joyride
'67 VW Crew Cab Turbo truck parts hauler
www.eurovintageparts.com
it is a 1976 bmw 2002. i am having problems with the horn because the 320i and the 2002 have different setups (they reversed the horn setup, so the horn isnt functional).
That's what I used on my '74. I had to dremel out the plastic button that used to hold in the 320 ring to make the '02 button fit in it. I had to puncture through the rubber on the inside of the hub (below the emblem) to solder the wires together and I had to shim the wheel about 1/8 inch. Works like a charm and looks "stock-ish".
The 320i wheel is a little bit smaller in diameter than the '02 wheel and the rim is a little bit thicker for a better feel.
Fishhead
Motorcycle Big Brake systems
Be yourself and be free with your thoughts because those who matter don't mind and those who mind don't matter..
Thanks!
I don't know if you had the stock '02 wheel to compare the 320 wheel to, but the 320 wheel feels a lot better than the larger, skinny rimmed '02 wheel.
Glad you figured it out.
Fishhead
