1971 BMW 2002 - nevada
BrianMR1987
1971 BMW 2002 -Nevada
Registered in South Dakota though has never been there
Nevada car currently in NorCal
$7500
Built late 1970 but was not sold until 1971, it has the 6 fuse box from the pre 1971 cars and some parts on the car on half post 71 have pre 71. Quirky interior and sunroof installed many years ago. I was told I am the 4th owner by the previous, and that the sunroof(does not leak), A/C and seats where dealer option done by the original owner. Car sat the awhile with the 2nd owner but has been made into a deceit driver status by myself and the previous. Looking to sell and move onto another car and going a different direction. I believe price is fair for condition and completeness of the car. Comes with a few boxes or interior bits, lights, manuals, spare parts, etc.
Exterior
Original paint still shines good but could use a good detail
Small dints and dings here and there
Some bubbling on lower driver fender
Rockers a bit brittle as seen but not rotting from within
Rear has slight dents near license plate area
Red euro tail lights (have originals)
Interior
Seat are in good condition although small tears on both headrest
Carpet on slightly worn with no holes
Dash has several cracks
Plastic on AC center is a bit warped but unit blows cold
All gauges work along with heat
Engine/Driving
Original solex carb
E brakes works as intended and brakes stop straight
Choke works well for cold starts
Pulls smooth/straight and up shifts well
Aggressive downshift can cause slight grinds with old synchros
Shocks are old, have used Bilstein shocks/H&R springs in box
New spring pads all around with camber plate for the front in box
Done within the last 2 years with receipts
New tires or original rims
Gas tank clean and fuel system one through
Powder coated factory 13s
A few window gaskets replaced
Driveshaft gimbo and support bearing replaced
New front rotors/pads
New rear drums/shoes/wheel cylinders
Stainless Steel exhaust (Ireland Engineering)
Stainless Steel Downpipe (original exhaust manifold)
Carb tuned up/vacuum leaks address
Clutch slave cylinder
Steel braided brake lines
Various services such as oil/cooling/transmission
Mild shifter bushing rebuild
post-48061-0-21976800-1423731955_thumb.j
post-48061-0-80905800-1423731955_thumb.j
post-48061-0-67411700-1423731956_thumb.j
post-48061-0-56004900-1423731957_thumb.j
post-48061-0-59442900-1423731977_thumb.j
post-48061-0-68033500-1423731978_thumb.j
post-48061-0-84671100-1423731979_thumb.j
post-48061-0-20034400-1423731982_thumb.j
post-48061-0-41993800-1423731983_thumb.j
post-48061-0-44717800-1423731984_thumb.j
Edited by BrianMR1987
