Ok, am I the only one having trouble with 250mm brake shoes?
So, I purchased the 250mm rear brake drum upgrade from IE and have run into trouble. Pretty straight forward but the shoes supplied don't have a spacer to allow for the upper spring placement. The two parts are directly riveted together and its way too tight to get the spring between the shoe and brake lever. I know I could bend the crap out of it but its just going to cause wear and sooner or later eat the spring. Jeremy at IE did send me a second set of rear shoes to try but the same problem exists. Anyone dealt with this or am I doing something incorrect?
Middle pad is my old one.
post-42021-0-23885600-1428973358_thumb.j
post-42021-0-38695800-1428973427_thumb.j
Edited by GirtAllerton
These were stock size shoes, but I had to return a set to Autozone for that some reason: No spacer between e-brake lever and shoe.  It just can't be made to work.
 Another parts store ordered some OEM shoes, and they had the spacer, and worked fine.
Edited by KFunk
Bring a Welder
Same thing happened to me, also with Autozone if I remember correctly.
