Solex PHH 40 float level procedure and setting
pierre02ti
After 10 years, I started to look into the float levels on my 69ti as the performance was lower than expected.
Procedure I used:
-disconnect the fuel lines
-remove the top of carbs. There is fuel leaking in the bowls at the moment!
-check fuel level from top of carb
Setting:
-Was at about 24 mm
-ran better at 22 mm
-setting in Haynes is 19 mm, where it is now but with hesitations at mid throttle. In the seach, this could be caused by fuel level too low!!
-Mikuni manual on PHH says 12 mm from float to carb cover when sitting on needle valve but not compressed. Is is far from there with a fuel level at 19 mm!
Need help. Your successfull procedure and setting will be welcomed.
Pierre
Pierre
69 02ti
91 318is
